Copper flakes in oil pan - Kawasaki ZX-10R.net
 8Likes
post #1 of 57 Old 02-13-2016, 05:10 PM Thread Starter
Carlos76's Avatar
Help, my engine produces "gold flakes"!
Removed today oil pan from my Gen4 engine just to check if all looks good from the botton and saw quite many copper flakes in oil pan!?
Made a photo of it. Has anyone had similar issue?
There are no larger pieces, only flat flakes (0.5 to 1.5mm) you see on picture.
Did cut open the oil filter and found copper dust there too.
Upwards from oil pan everything is very clean and cannot see any debries there.
Where can it come from?
I can exclude clutch and cylinder head, it is off and valve clearances were good.
Carlos76 is offline
post #2 of 57 Old 02-13-2016, 05:14 PM
dricked's Avatar
Bottom end bearings. I'd replace them NOW before you spin one and need a crank/head/valves/oil pump. It's a bit expensive to have them done but it's 1/2 the price of repairing the motor after the fact. Gives you an excuse to have the crank lightened too :)
AirborneMechanic and mpp12 like this.
dricked is offline
post #3 of 57 Old 02-13-2016, 05:17 PM
Supercharged Mod
Yup. "Badness has occurred." Pull it apart now, before it does more damage.
If you find out that a rod bearing has gone bad (which is likely), measure the journal and the affected rod very carefully for out-of-round or out-of-tolerance.
GoFaster is offline
post #4 of 57 Old 02-13-2016, 05:30 PM Thread Starter
Carlos76's Avatar
Shit, I was hoping something from gerbox area. Did not know crank/conrod bearing produce copper color.
Carlos76 is offline
post #5 of 57 Old 02-13-2016, 06:01 PM
gazx10's Avatar
only place it comes from.
gazx10 is offline
post #6 of 57 Old 02-13-2016, 06:11 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
Crank main or rod bearings are the only 2 places for them to come from.
Do loke what was said earlier and pull the crank now or you will trash the motor.
hellsrazor is offline
post #7 of 57 Old 02-13-2016, 06:49 PM Thread Starter
Carlos76's Avatar
Thank you for info. Will split the crankcase next week.
Carlos76 is offline
post #8 of 57 Old 02-13-2016, 07:14 PM
SkyDork's Avatar
What everyone else said. Not good and looking at a big repair bill. Crank will need repair or replacement if the bearings are starting to shred. I'm just getting my crank back and will be starting the rebuild soon. It sucks.
#WordCrimes
SkyDork is offline
post #9 of 57 Old 02-13-2016, 09:08 PM
g-man's Avatar
Wow, how many miles on that?
g-man is offline
post #10 of 57 Old 02-13-2016, 11:00 PM
dricked's Avatar
dricked is offline
Gen 1: oil pan Slow10r Wanted: Buy or Trade 0 09-15-2012 05:28 PM
Gen 2: In need of an oil pan. mpickron Wanted: Buy or Trade 1 02-22-2012 06:18 PM
found brass flakes in my oil copperelite Performance and Tech 15 01-20-2011 06:22 AM
oil pan redzx10 Vendors deals 1 08-05-2007 09:31 AM
Oil Pan? BeepeR Vendors deals 1 04-04-2005 07:49 PM
