kick stand problem! need help
2K views 8 replies 6 participants last post by  KawieKrazy
#1 · (Edited)
My kickstand safety switch on my 08 zx10 is dead! I can't even crank it up in first gear! thought about replacing It but would rather remove it. Anybody have any suggestions or know the best way of taking it completely out?
#2 ·
The kickstand? If it were stuck down you wouldn't be able to start the bike in gear due to a failsafe. I would replace it. I see your bike is streched so an adjustable one might be best but I don't know how you could survive without one.
#5 ·
Had the same problem on my 06 when it was brand new. Went back to the dealer 3 times. The bike would just cut off due to the vibration triggering the switch. Almost got killed several times :headshake
Good luck and be careful.
#6 ·
Which do you think would be better? Tie the wires together closer to the fuse box or just cut them where they sit? I would rather go with the fuse box! Then you wont be able to see the wires hanging.
