1 - 16 of 16 Posts
Hey guys,
I have an 07 zx10 and im not happy with the braking perfomance and was reading that swapping in the nisin zx14 calipers were a realtievely cheap fix to the issue. if i do this swap i will also be doing ss lines...any thoughts or guidance?
thanks
Yup, searching will provide the answers you need. It's a popular mod and there's plenty of info for you on this. It's well worth the effort to do the swap.
You don't really need ss lines... The standard lines are sufficient.
Thoughts... Have a good look at the crush washers between the bolts and banjo fittings. Some people re-use them, but they are cheap at Kawi...
I've had the 14 calipers on my 06 and Blade calipers on my 07. Both with standard lines... No issues.
Can u use the same brake pads for zx14 from Orem zx10r. Caliper.. ?.. Also do u need to bleed the brakes right
No, the ZX-14/ZX-6/Concours Nissans use different pads than the ZX-10. And if you're swapping calipers, of course you'll have to rebleed the system cause you have to disconnect the lines.
Ok cool thanks I guess I'll just wait to order my ss lines then ..
Does not drive into smoke
I was tempted to try monoblock calipers from R1, but I already have Nissins from ZX-14, and I didn't want to mess with it again (or spend money). However, if anyone is willing to give them a shot, I'd like to see a review. :smile:
Pretty sure that's been done, but far too long ago for me to remember who. I wanna say the person who did it had a green gen 1 but yeah...that memory thing.
1 - 16 of 16 Posts
