1 - 5 of 5 Posts
Just wondering if anyone can help.
The dash or trim seems to be incorrect on my 10, it has been like this from new and the
top fairing has never been removed. I have pushed the trim down and it won't move also the dash is
solid and will not move, any ideas?
There is no adjustment with the mounting bolts of the gauge cluster and you won't be able to adjust the position of it unless you started elongating mounting holes or fabricating new mounting points.
If you like taking stuff apart for kicks then be aware that everything layers in a bottom to top fashion. To get to the cluster you'll have to start by removing one of the lower side fairings, then the mid, also the inner fairing above the tire, dash panels, mirrors, windscreen and center fairing. The center fairing also has 2 hidden screws that are very hard to find. I also might be forgetting a few steps.
  • Like
Reactions: Greenblood7
1 - 5 of 5 Posts
