1 - 6 of 6 Posts
ZX10RR 2017 is it possible to keep the abs on a trackbike?
We are 4 friends and we all bought zx10RR 2017
All my friends throw out the abs, but i plan to give the abs a chans on track. I hope that the abs is sofisticated as a 2017 modern superbike should be and hope the abs is not activeting to early.
Do you think it is impossible to take short breakdistance with abs? The zx10RR is build almost as a racebike, if this is a race adapted intelligent abs, why not keep it?
We are testing in Jerez 6-9 february so i will see, but lets hear your opinion.
I bought the dongle and disabled the rear only on my 2016 KRT. The front ABS was never an issue for me. It will let you bring the rear off the ground and the ABS doesn't kick in. The only time I find it ever kicks in is if the front wheel actually locks and slides and that never happens for me on the track. I have had it kick in on the street if aggressively braking coming to a stop sign and have the front wheel lock.
Discussion Starter · #3 ·
good news
but i don´t have some dongle for disable the rear .... i try not use much the rearbreak
good news
The dongle also lets you disable the front brake (although you would have to do it every time you start the bike). I also am not sure if it changes the behavior of the front brake. Maybe with the dongle it allows you to be more aggressive on the brake before it kicks in, I'm just not sure. I know on my new Super Duke the dongle gives me another mode (called SMOTO) that allows me to bring the rear off the ground where the standard street mode doesn't. I didn't ride the bike much before buying the dongle from the race kit (it's only about 20 bucks). Regarding disabling the rear. The rear obviously comes into play if you ever get out into the grass. I got knocked off the track when testing my bike out right after I bought it and the ABS prevented me from using the rear as much as I would liked to have. I didn't have the dongle at that time yet. I ended up going directly into the tire wall at about 65mph and I believe I would have been able ot get the bike slowed down a lot more if the rear ABS had been disabled.
My bike is track only and you absolutely have to get rid of the ABS. Most people concentrate on more power not realizing how important it is to have great braking to be able to use the extra power. The abs system kicks in relentless on the track and there is a lot of extra fluid in the line. Moreover there is a section with rubber only lines. You need to get braided lines and a new MC to get the best possible braking.
We run KIT harness and ECU on all of our ZX10's and get rid of all the ABS system when swapping out the harness. Even running in the bikes in stock trim you can feel the ABS pulsing in the lever. It doesn't let you brake hard enough for the track and you're better off getting rid of it and setting up braided lines as soon as possible.
1 - 6 of 6 Posts
