1 - 2 of 2 Posts
Wanting to see if any of yeah are running a 14 shock on your bike if so. Is it any are than a 10 bc my 10 shock is letting my bike flex way to much.
Not sure about the 14 shock.
But I believe what you are saying is your shock spring
rate is to soft for your weight.
You should be looking at the stock spring rate vs
spring rate recommended for your weight and then if it's
off you can replace the spring.
Replacing spring is around $100
Check out the weight/spring rate calculator at racetech
Race Tech Suspension
1 - 2 of 2 Posts
