21 - 40 of 51 Posts
Discussion Starter · #24 ·
then I install titanium parts again
made the rear engine mount studs
upper rear shock absorber mount
Oem
my detail
pendulum axis with eccentric mechanism
Stock
My detail
as you can see, we do not just copy the details, but modify them
we also made a titanium rear wheel axle with a nut and a magnesium chain tensioner stop
Oem
My detail
the axle can be made lighter, but there are some concerns
Discussion Starter · #27 ·
I also wanted to install a monocoque rear subframe on my yamaha r1, but unfortunately I could not do this. It turned out to be a little easier with kawasaki, but I waited for this detail for about a year
I also installed a new glass, I do not know who its manufacturer is, I bought it on wrs.it high flexible and does not distort the view
Discussion Starter · #28 ·
in this configuration drove 2021. improved time on two of the three runs I have ridden. on track days I was not lucky with the weather, so I spent a little time on the track. also found errors in the traction control system (fixed by ECU firmware). The motorcycle now weighs 162.5 kg with oil, antifreeze, battery, but no gasoline in the tank.
Discussion Starter · #29 ·
I also found out that the location of the footpegs does not suit me. but there is no way to move it closer and raise it higher. that's why we made modified plates
when I find a comfortable position, I want to make the footrests without adjustment to remove all these plates and bolts.
but now I will only be able to try in 2022.
In the meantime, the time comes for new dorobotok and tuning))
I hope we can make our plans come true
Wow. Very impressive build!
Discussion Starter · #36 · (Edited)
I upload a video of the assembly of the motorcycle to YouTube.
can be viewed with automatic translation
I'm following this build, are you going to make & sell some of your custom made parts? I'm interested in a few things.
Titanium chain guard with rectifier regulator bracket.
Titanium upper shock mount.
Titanium front & rear wheel axles.
Titanium swingarm axle.
Titanium swingarm eccentric inserts.
I'm in the process of building a 2018 ZX10RR track bike for myself & your craftsmanship is superb. Hope you're doing well.
Discussion Starter · #40 ·
Thanks buddy!
Unfortunately, due to the situation in the World, I will not be able to sell and ship parts to another country.
And buy too. because of this I am now having trouble building my kawasaki zx-7r.
21 - 40 of 51 Posts
