In fact, the bike is almost ready, it took almost two years, so maybe there will be a pun in the description.
I decided to do everything with it that I didn't do with the previous Gen 4
First of all, the motorcycle was disassembled to the frame.
the photo shows all the wiring from the motorcycle and its weight on the scales, Her weight is 5.4 kg.
My motorcycle is from Europe and has an immobilizer, so I took the wiring and ecu from the USA zx10rr
This made it possible to remove the ignition lock and antenna, and the ignition is now switched on by the red button on the right
Then I dissolved the wiring, removed all unnecessary and moved the ECU to the front, as in WSBK motorcycles
After these manipulations, the weight of the wiring together with the relay controller is 1.6 kg.
ABS and an electronic damper were removed from the wiring. The diagnostic connector has also been moved forward. only the battery and the starter relay remained in the tail
