1 - 20 of 108 Posts
Servo's Eliminatus ;)
This is my FREE SHAREWARE on "How to build your own servo eliminator"
For a Gen 1, 2, 3, ZX10R ONLY...
I figured it was time to update my old thread to make it a little easier for peeps to understand
"How To Build It Themselves".
Read the entire 1st post, it contains all information needed to do this.
1st. I bought my Electronic parts at Radio Shack (Free Plug for them)
All pictured in the 1st Pic. Part #'s are on them.
**Note** In the 3rd pic the capacitor says 16volt,
but you can use the 35VDC instead. Radioshack is out of the 16volt.
2nd. You will need, A Soldering Iron, Solder, Electrical Tape, Epoxy.
3rd. Tools Needed : Needle nose pliers, Wire Strippers.
4th. Remove your Exhaust Servo Motor from your bike,
Cut the wires off of it as close to the motor as possible.
5th. Cut the GREY wire off the back of the one connector leaving the RED on.
On the 3 wire connector, leave ONLY the Black & Yellow wire on it.
6th. Assemble the Capacitor and Resistors as pictured in Pic # 4.
Make sure the arrows on the capacitor are pointing
at the black wire.
The resistors direction do not matter.
DO NOT DEVIATE from diagram.
I assume NO responsibility for any damage
7th. Solder the resistors to the capacitor to keep them secure.
Solder the circuit to the wires. Follow the diagram.
8th. Set the completed circuit in the Epoxy tray and pour Epoxy.
When Epoxy is set, remove and trim any sharp edges.
9th. Wrap Epoxied circuit with Electrical Tape.
10th. Install on your bike and you are done.
Now, If you cannot do this yourself.
I can and will build one for you, just PM or email me at
[email protected]
This has been verified to work all Gen 1's, 2's, & 3's.
Does not work on Gen 4 ZX10R's or ZX6R's.. Sorry
I do however, build ones for the Gen 4 ZX10R and ZX6R & Z1000, Z750
Don
Great write up.
FYI, Amazon sells a 10pk of resistors for $0.98
just curious though, what does shipping cost on that?
Oh SNAP, I just realized your in Japan bro.
You need me to hook you up with some??
If your gonna do it yourself, I can send you the parts.
Or I can build a complete one for ya, let me know.
Hellsrazor I may end up pming you for parts. Nobody will ship resistors here...even though they're probably made here anyway.
Discussion Starter #7 (Edited)
Not a problem bro, let me know.
Also, I now have complete units to where you don't have to send me your harness and wait on a turn around time.
They are extra shipping to Japan.
Unless you are in the military and have an APO address,
and then it's like shipping inside the states.
If you aren't in the military, find a bud who is and ask him if you can ship to his APO address and save some $$$
I'm sorry, maybe its late or something, but I find that funny as hell :spit:
Hellrazor great write up, clear, and concise. Will be doing this project this week.
Thank you. :eek:ccasion1
Cool, post back up when you are done.
Glad it helped you bro.
I smile everytime someone doesn't have to pay $120 for an Ivans,
Or even $60 for the other one.
What does this actually do? Pretend I don't have a clue, only because it's the truth. What does the servo do? I have a 3rd gen with a slip on.
My experience with modern bikes is with an 03 z1000 so I'm not familiar with servos. Thanks for not flaming my non-knowledge.
the exhaust servo is a valve on an actuator that is controlled by the ECU. Its function is to supposed create addition backpressure at lower RPMs by slightly closing to restrict exhaust flow, opening in the midrange RPMs to allow full exhaust flow for the most power, and then close in the upper RPMs to reduce noise for the EPA and those other folks who dont like loud motorcycles. On a Gen 1, the servo is located in the header.
To disable the servo you can do a few things. 1, remove the exhaust valve entirely by installing a full exhaust system. 2, unhooking the cables that run to the valve so the servo cannot move it. 3 (an additional step to 2), unclip the servo motor and remove that and the cables that run to the exhaust valve.
This mod is designed to create the circuit that is completed by the servo motor so that the ECU does not tell the gauge cluster to flash an FI Error, as removing the servo motor will. Hells made it very cheap instead of having to buy one for 4 times what you would spend on this. It is however, slightly more expensive than the black electrical tape mod. The nice part is that this mod will let you get an FI light when something is actually wrong with the bike and not just for the servo so youd never know.
Discussion Starter #13
:spit::crackup: The Black electrical tape mod :lol::lol: Good one.
Thank you for explaining that for me bro. :thumbsup:
As of yet for the Gen 4 :headshake You will have to have that done when you flash the ECU.
Trust me, If I can figure it out for the Gen 4, I will post it up.
So far I have one for the ZX10R's Gen 1-3, Z1000's & ZX6R's.
Dude! you rock! cant thank you enough for this thread! Did my FI light eliminator as per your instructions! works like a charm! especially the satisfaction of making my own component for the bike!
Rep sent!
Discussion Starter #15
Rep sent!
Glad it helped you out bro. :eek:ccasion1
Which bike did you do it to?
I was looking at your list of bikes.
Was it the Z1000 or a ZX10R? And what year.
Thanks for the write up hellsrazor. I do believe I can find pretty much everything around here (Canada). I smell a little project coming up :)
Discussion Starter #17
Glad I could help you bro. :thumbsup::eek:ccasion1
It's funny cause it true! Lol
And great write up
Nice explanation.
Mailed out another 2 of em today.
Gonna be checking the box like it's Christmas. The motor servo finally threw the FI code last night. That shit is bright as hell...and annoying.
Nope abondonded the z1000 project , did it for the zx10r (frst gen) works like a charm!!
i have seen write ups before, but hardly any of them provide good links to source the items, your thread really helped a lot especially for some one like me who has very limited electrical knowledge!
thanks!
1 - 20 of 108 Posts
