So, not sure why you're posting pics of that head gasket. There's so much wrong in that ad. :headshake:
As stated, no the Gen 4 and Gen 1 heads aren't the same. Neither is the head gasket, which is what i think you posted ads for. But I'm thoroughly confused by it. It says "cylinder head rocker cover", but shows a pic of the head gasket. The ZX-10 doesn't use rockers and the valve cover (where rockers are normally used) is completely different than the head gasket.
I would NOT buy that gasket. It's from some unknown company that can't write a matching description. I have no idea what you're trying to even buy since the Gen 1 and Gen 4 heads are not compatible. And I'd buy the OEM Kawasaki gasket depending on what you're looking for.
