1 - 3 of 3 Posts
Hello everyone I have a zx10r 2018 I have failures when it comes to accelerating thoroughly it drowns at 11000rpm and then at 6000rpm, why is it drowning? It seems like a pump problem and I changed it and it remains the same or worse, but maybe it could be something else thanks for your help.
The ecu is flashed Woolich
2018 ZX10R SE
You said you have the ecu flashed right, before doing anything else. Flash a base map back to your bike. Do not select restore to stock or you will have to buy a new bin file but use either the uploaded euro or stock map that is in the map share. Or ya know one of the favorites on there. Also, you give zero other realavant info about your bike. What mods do you have and are you using a custom tune done at a shop or by you or one that you downloaded off of mapshare? Do you have the matching mods if you downloaded one etc. These things matter
1 - 3 of 3 Posts
