1 - 5 of 5 Posts
Hi,
My bike as been down the road and I have now stripped everything off ready to make it into a track bike, problem is it won't start.
Basically everything works ok and the bike turns over but.............
Fuel pump does not prime and FI light does not light up for the two seconds after the ignition is turned on.
Anyone got any ideas ?
Adam
I have exactly the same problem.
Crashed the bike and after some healing time are trying to get it back on the road/track and it wont start.
spent 2 days stuffing about with no result. however when i poured some gas staight down the bellmouths is started up. the FI light is flashing and the oil pressure light does not shut off after. Any ideas???
Peter.
The bike has a tip-over sensor usually located under the rear tailsection fairing or front fairing. If the bike has been layed down, it shuts fuel off, the bike will turn over but won't start. Disconnect battery for several minutes and make sure the sensor is facing the right direction (it has an arrow on it, should point up). Reconnect the battery and give it a shot. That may be all it is.
1 - 5 of 5 Posts
