1 - 4 of 4 Posts
Anyone know if the clutch fibers and.steels are the same in a 04 zx10 as an 05 zx12??
Sent from my HTC Sensation 4G using Motorcycle.com Free App
The part number's will probably be different from the factory, however a bunch of fibers will interchange even gsxr 1k. I've had 02' zx9 fibers in my bike and they worked fine, if you match up the plates and they line up they'll probably work. If you look up aftermarket part numbers like EBC I know they re use a lot of the same fibers in different bikes but look up the individual plate not the kit to see if the 10 and 12 will interchange, just make sure the stack height is correct its 53.5mm for 3rd gen not sure for 1st gen but should be close.
Awesome ill match up numbers and see what I come up with. Thanks guys.
1 - 4 of 4 Posts
