1 - 14 of 14 Posts
Just finishing up porting the head, now its going to get a valve job on a serdi millenium, I also had the crank balanced, and I will balance and prep the piston before they go back in.
Kawi race cam will be set up for upper top end power.
I am waiting on main bearings and rod bearings and I will start to put it together.
Discussion Starter #7 (Edited)
I am expecting in the area of 175-177 h.p.
But I might not ever know it will not be on a dyno anytime soon
all tunning is real world tunning.
Discussion Starter #8
To both questions asked about valve size,It has stock valves.
My finish on the ports are hush hush lets say a bit more than most
guys who port use, I find you dont lose alot of flow, but get better
atomizing from the fuel and make more power.
Schweet! Let us know about all of the kills!
You should order hi comp. pistons while you wait for the headwork.
Discussion Starter #11
I am still working on that with the owner he is not budging right now.
just 175??? I have 172 with out porting , cams, by the way that was before I take the engine . I expect to see 180 + on your bike. good luck
1 - 14 of 14 Posts
