1 - 3 of 3 Posts
OK GUYS, im putting the ZX14 rotors and GSXR calipers on my bike but I need longer caliper bolts, the stock zx10 bolts are 60mm long and I need 65mm. 70 mm is too long. Any one know the length of the GSXR bolts?-06--07....
Gun Owning Republican
I do not know the length but want to commend you on the caliper exchange with gixxer ones. Rep sent...The 1000RR calipers worked great and I hope your caliper exchange does so as well.
just cut 5mm of the 70mm ones. grinder,cutoff wheel, hack saw, then chamfer the bottom of the bolt and your set. I mean if your really need it mail them to me ill chuck them up in the metal lathe and cut them for you and rethread the 5mm longer just to make sure.
1 - 3 of 3 Posts
