1 - 5 of 5 Posts
I would guess that the latest cases (05?) are the two hole. On the GSXR 1K, the difference between the early motors (01/02) and later (03/04) is the air passage holes. The holes add 5 Hp.
The main bearings diameter in the block. You won’t to get a case that matches the crank and clutch basket gear or you can have problems.
and they have to be a paired set
1 - 5 of 5 Posts
