1 - 3 of 3 Posts
Hey Peeps, Just just wanted to know if anyone has installed one of these pipes on the 08/09 zx10r, and wether they removed the servo under the seat and/or just the cables that went to valve in the original monstrocity of a pipe completely from the bike?
Also will disconnecting this bring up any warning lights etc ? Any help would be apprieciated :)
Pipe hasnt arrived yet,just researching in advance :p
Cheers,Theo
Chickenstrip Eater
Coulda searched but I'll play nice.
Disconnect the cables at the servo under the seat-Remove the servo wheel itself and tuck the cables out of the wy or remove them if you feel froggy. The servo under the seat runs the cables that run to the butterfly in the can. DO NOT DISCONNECT THE ELECTRICAL AT THE SERVO MOTOR. If you remove the electricl connection your bike will throw an FI light/code.
1 - 3 of 3 Posts
