21 - 33 of 33 Posts
Squid wannabe
Forgot about that. Where you line ip makes a difference too.
You want to be in on of the two "tracks" where the car tires would be. Not in the middle of them.
Yup, watch and see where the cars are launching from and then line yourself up there. Itll help a lot with traction. Too be fair, I have spun my Q3 after lining up properly and all. I think track prep may have been an issue or something. Or I messed up the launch (most likely culprit). Youll be able to feel the sticky spot on the track with your boot though.
Discussion Starter #24
Nice. That's what I'm shooting for. I'm up in Denver so we lose a little to the altitude but 9 is definitely doable.
Funny thing is my starts were usually good at roadraces but can't dial them in at the strip
Did the bike try to wheelie?
i'm geared at -1/+5. I run 1/4 and i'm typically clicking 6th gear just before the stripe. My best 60's have been 1.50's.
Went to the track last night, didn't do anything impressive. I trimmed down my clutch switch, thinking it'd be better for launch. Turns out, I was wrong. I shortened it too much, so now the bike leaves the line while still on the 2-step. I found a switch on ebay for $12 and wasted no time ordering it.
Discussion Starter #29
Have a 15t front and a 42t so might try couple different combos.
Hitting the limiter in 4th right about the time I cross the traps.
if your having traction/wheelie problems. Try adjusting your suspension. Here's a pretty good vid that explains sag and rebound settings for drag racing.
https://youtu.be/ZsIcE5GoGvk
Discussion Starter #32
Yup, clutch is going.
Does running Kevlar plates and stiffer springs cause an issue the slipper clutch?
Dont know about the kevlar plates, but stiffer springs are fine. I think a lot of people who drag their bike has stiffer springs.
21 - 33 of 33 Posts
