1 - 2 of 2 Posts
when i reset my throttle position i see numbers like close=15xx and open=23xxx. i have no idea what they mean. at idle i have 22% throttle.
what do the reset throttle position numbers mean?
should i set the throttle positon sensor so that i have 0% throttle at idle?
Yeah at idle (0% throttle) you want to see 0% on the pc screen. Just click the left arrow and the value your throttle is reading will be set for your 0% setting.
Do this at operating temperature though or it won't be accurate, or you can also reset both 0% and 100% by clicking the reset values button, let er rip all to WOT real quick so you don't redline the fugger and you will be all set.
1 - 2 of 2 Posts
