1 - 7 of 7 Posts
· inappropriate
just bent my left side stock adjuster for my 04, i need a quick replacement and later a strong and suitable upgrade.
· inappropriate
Discussion Starter · #4 ·
Yeah the bolt. Both sides are actually bent after I took them off. Just ordered a set champs which ones with new hardware. I figured I'd try the hardware store for some replacements but am unsure of their quality the over stockers
just pull one out and match it up with a high grade 10.9 or higher metric bolt, was the axle loose? they shouldnt bend. Or you could just get an arm done then you wont need them.(maybe its a sign that it wants to be longer) :thumbsup:
· inappropriate
Discussion Starter · #6 ·
Haha I think it is. I'd replace it but I decided of was time to upgrade the adjusters anyways. The axle was tight, that's the first thing I checked. I always crank that nut down.
· MIdlife PIMP
you will be happy with the Champs man!!.......very nice pieces!..plus the adj marks are much more intracate!.........makes adj a breeze!...........plus they look trick!!!
1 - 7 of 7 Posts
