1 - 14 of 14 Posts
Woolich is so much fun adjusting things like the autoblipper and seeing instant results. I had just left it as switched on and the RPM. You think, this is cool I have an autoblipper! Then you go back and see you can adjust the time & TPS on even the standard autoblipper, not the race tools version. Holy shit it made a difference, before sometimes when I shifted down the bike would lurch forward a bit. I googled autoblipper times and the results were around 50ms to 60ms and mine were the standard 100+ms so I changed mine to 60ms. It feels like a seamless shift gearbox now, butter smooth downshifts with zero lurch forward. Pressure I set at 4 out of 10. the lighter ones 1,2,3 especially 1 are so light it changes twice or misses altogether. 4 is solid & now super smooth. I love it.
Is that what everyone is running on a 2016 ZX10R ? 60ms / level 4 / TPS I left as it was / 2500rpm 200ms & between changes.
I have experience with woolich and have used it to flash my zx10 se 2018 ... but the software only allows me to change some quickshift values that are in 100 inside Advanced Settings. The autoblipper part is in the Race tools and they do not modify anything without the specific key.
Above Advanced settings on the main screen is the Autoblipper button. If you click on that and activate the factory Autoblipper the rpm and time between shifts is available to change and lower down you can change the shift time in ms and the TPS in each gear and 1000rpm. Mine is a 2016 though, doesn't the 2018 already have an Autoblipper? Maybe your version of Woolich doesn't have the Autoblipper button?
Thanks! I don't have that button, probably because its a SE 2018 I have to pay for Race tools to use it.
444218
Thanks! I don't have that button, probably because its a SE 2018 I have to pay for Race tools to use it. View attachment 444218
That sucks. It made an unbelievable difference to just enabling it & leaving the settings untouched. The standard upshifter is super smooth, now with those shift times the downshifter is probably a bit smoother again. It was pretty rough on the enable setting which I first thought was to do with the 1 to 10 pressure. The bike would lurch forward on downshifts, that's what made me investigate it further because the settings were right in front of me I just needed the right ones!
Maybe email Woolich and ask why your version doesn't have that button? It does say 2016-2018 ? Never know your luck
18 zx10r
Thanks for clarifying that. Sucks that the settings got lumped into the "race tools" package. That's whats held me back from buying a kit for now. I might as well send it off for a flash if I can't adjust that without spending another couple hundred dollars to enable the adjustment feature. I also contacted FTECU they have adjustable cut and blip times included in their features but to no avail.
I guess the other option would be to buy another bin file key for $100 but choose the 2016-2018 ECU that has the Autoblipper button. You would just have to find out if there are any reasons why you couldn't flash a newer ECU with a previous models settings. The ECU would be the same manufacturer & other than Woolich trying to get you to buy the race tools package I wouldn't expect it to be incompatible. You could scroll through your current settings and copy and paste them anyway.
I haven't looked up the cost of Race Tools but that would have to be an option to adjust your Autoblipper.
I would be asking Woolich why they dropped a free option on the newer bikes 1st ?
18 zx10r
Is this for an 18 zx10rr?
What year bike do you have?
2016 - but I got even better settings from another post about the ETV setup. Now the throttle and Quickshifter are perfect.
There is a download with all the settings and a great map you can copy and paste into Woolich then flash your ECU.
will test after this pandemia.... mine lourches a lot, the stock settings where above 100ms
Discussion Starter #12
Yes
Also found a whole bunch of great settings shared by Tdh. Download his settings then copy and paste to Woolich.
I have been riding with all of those settings for the last 1500kms and I love it. Bike is so smooth down the gears.
His ETV map is perfect.
http://knauerracing.com/files/ZX10R-Woolich-MyMaps.ods
The fuel map is also on there for a Graves full exhaust. It's a spreadsheet format but it is easy to select the areas and copy and paste to Woolich.
10 out of 10
Cheers
Ash
very nice maps, ETVs are very well made, abruptness in the low TPS are very nice corrected.
I will try the autoblip...
Thanks
Discussion Starter #14
Try riding it. Bike is so stable.
I am not touching anything anymore. Those settings are perfect.
Thanks TDH for sharing.
Cheers
Ash
1 - 14 of 14 Posts
