No worries, enjoy!!!Thanks for the map Ashley
How can i have the map? since im using a Zx10r 2020.. Mapshare wont let me download it. .. PLease assist.. appreciate in advance..Yes the 3rd of April is the latest maps
2016-2018 Kawasaki ZX10R ECU Flashing Tuned Map - Upper & Lower Injector Autotune 3rd April 2022
Upper & Lower Injector Autotune 3rd April 2022 - Tuned Maps for ECU Flashing the Kawasaki ZX10R...www.woolichracing.com.au
The ECU for the 5th gen changed in 2019, so you'll need to purchase a Woolich BIN file in order to access earlier (2016-2018) Gen 5 mapshares on Woolich's site.How can i have the map? since im using a Zx10r 2020.. Mapshare wont let me download it. .. PLease assist.. appreciate in advance..
Sad.. appreciate for the reply though... cheersThe ECU for the 5th gen changed in 2019, so you'll need to purchase a Woolich BIN file in order to access earlier (2016-2018) Gen 5 mapshares on Woolich's site.
BTW the created tune referenced in this thread is for a 2016 model.
That is what I am trying out now. It needs a few more AutoTunes though. The F & M maps power wheelie but this 1:1 map seems to have a fantastic launch but bogs down in the middle revs compared to the other armripper maps. Maybe I need to make a new ETV with part of this map down low and the other map for the rest to get the best of both worlds. I got my new Bayliss Ducati Panigale V2 so it takes alot longer to get things done because I like riding all of my bikes!!!When I first began fiddling with Woolich about 2 years ago I recall one of the other popular Woolich Mapshares that had a 1:1 ETV map. It got great feedback and I think the reason it was so popular was because of the aggressive and responsive 1:1 ETV map, and not other parameters like the fuel/ignition. The 1:1 ETV map will definitely rip your arms off when grabbing a hand full of throttle from down low, and you can feel that constant power on tap at all RPMs. This is how the ETV map is setup in the Kit ECU and FlashTune's ECU Tune Kit, 100's in all cells.
Congrats on your new bike!That is what I am trying out now. It needs a few more AutoTunes though. The F & M maps power wheelie but this 1:1 map seems to have a fantastic launch but bogs down in the middle revs compared to the other armripper maps. Maybe I need to make a new ETV with part of this map down low and the other map for the rest to get the best of both worlds. I got my new Bayliss Ducati Panigale V2 so it takes alot longer to get things done because I like riding all of my bikes!!!
I will get there, it is coming along nicely
This had caught my attention after reading this post...page 2 start at post #30.Not yet!!! I did look at them at the same time as the ETV maps, it was either the Yamaha R1M or the ZX10R but one of them has a separate ETV maximum that overrides what you put in the ETV map as well. The standard injector balance looks pretty good, plus I spoke to a racer from the Isle of Mann on an english/British site years ago when I 1st got the ZX10R and he said the majority of his map is lower injector, 99% of it. That put me off trying my upper and lower injector tune back then. But no I haven't looked at playing with that yet....
Everything is intertwined so it can be dangerous just to go 50/50 on something like that, looking at the stock injector balance it is mainly the lower injector all the way, even at 100% it is still 70.3 lower injector & 29.7 upper injector. Obviously they both have to add up to 100 combined. Looking at the stock numbers they only change by 2 up to a maximum of 5.8 then lower again over the TPS range. Did you go 50/50 over the whole rev range? Or at a certain TPS?This had caught my attention after reading this post...page 2 start at post #30.
Gen 4: 2011-15 - Bsd ecu flash using Woolich mention...
What is the difference between group 1 and 2? I don't know, that would be a good question for Justin or ZX Sik R. My "guess" is gear groups, but it wouldn't seem to matter since they are the same, but I really don't know.www.zx-10r.net
I once tried the 50/50 split and my butt dyno felt a slight improvement in the 8000 + RPMs but I reverted back a stock map when one day I was riding pretty spirited and experienced something like a knock at high rpms. I couldn't pin point what was causing it so I changed my entire Bin file back to stock and started over with a fresh flash. The knock could've been attributed to something else but I played it safe and just started over.
