Frankly, no. Everything about that video makes me think that it's a low voltage condition. I can't tell what you're attempting to do with that small ass gauge wire grounding out with a socket, but that's not doing anything good either. Not sure what that whirring noise is in the video either. What is that and where is it coming from?
Get a set of jumper cables, hook them up to a car battery, and attempt to start the bike. Do not use that speaker wire to do it either. You need to be able to pull some amps through the cable and there's a reason the cables to the battery are as big as they are. :wink:
