Hi guys,
I have got a problem with my 2005 ZX10R.
2 weeks ago the frame has been welded(yes also had that problem :lol: ).
This week i put everything back together. Went for a test ride...first the FI light came on and i noticed a little performance decrease from the start. It was only a 3 minute ride to the gas station. FIlled her up...after that the FI light was gone...then for the first time i wanted to give some gas.
But it won't let me get past 5800rpm...its start holding back like a limiter. Its like it doesn't get enough fuel or something.
In neutral its revs normally all the way.
Do you guys have any idea?
Its not the exup valve/servo motor, already tested that. Lines to the fuel tank are good and to the airbox.
It could be i forgot a wire somewhere but i doubt it.
Or maybe the ECU got effected by the welding? Not sure if he disconnected it. I disconnected a lot of other wires and the battery was out.
Hope you guys can help me out.
