Good day
So I have started getting a no crank over for a few weeks now. After pushing the start button a few times it would start up. The past weekend I went on a trip of about 1600kms. Halfway it just stopped cranking over. With a small push it would start and would run like normal.
Let me explain:
I would turn the key and everything would come on like it always does.
I would hit the kill switch and the pump would prime.
I would hit the start button and it would just click from the relay.
I have swopped out batteries- same problem
I have changed the starter solenoid-same problem
If I short out the solenoid then the motor will crank over.
My next stop is to bridge out the side stand switch.
All the discussions I have come across on here never have an answer.
REALLY NEED SOME HELP HERE!!!
Let me explain:
