1 - 14 of 14 Posts
I'm currently running the latest version of GirlFriend and I've been having some problems lately. I've been running the same version of DrinkingBuddies 1.0 forever as my primary application, and all the GirlFriend releases I've tried have always conflicted with it.
I hear that DrinkingBuddies won't crash if GirlFriend is run in background mode and the sound is turned off. But I'm embarrassed to say I can't find the switch to turn the sound off. I just run them separately, and it works okay.
Girlfriend also seems to have a problem co-existing with my Golf program, often trying to abort Golf with some sort of timing incompatibility.I probably should have stayed with GirlFriend 1.0, but I thought I might see better performance from GirlFriend 2.0. After months of conflicts and other problems, I consulted a friend who has had experience with GirlFriend 2.0. He said I probably didn't have enough cache to run GirlFriend 2.0, and eventually it would require a Token Ring to run properly. He was right - as soon as I purged my cache, it uninstalled itself.
Shortly after that, I installed GirlFriend 3.0 beta. All the bugs were supposed to be gone, but the first time I used it, it gave me a virus anyway. I had to clean out my whole system and shutdown for a while.
I very cautiously upgraded to GirlFriend 4.0. This time I used a SCSI probe first and also installed a virus protection program. It worked okay for a while until I discovered that GirlFriend 1.0 was still in my system. I tried running GirlFriend 1.0 again with GirlFriend 4.0 still installed, but GirlFriend 4.0 has a feature I didn't know about that automatically senses the presence of any other version of GirlFriend and communicates with it in some way, which results in the immediate removal of both versions.The version I have now works pretty well, but there are still some problems. Like all versions of GirlFriend, it is in some obscure language that I can't understand, much less reprogram. Frankly I think there is too much attention paid to the look and feel rather than the desired functionality. Also, to get the best connections with your hardware, you usually have to use gold-plated contacts. And I've never liked how GirlFriend was totally "object-oriented."
A year ago, a friend of mine upgraded his version of GirlFriend to GirlFriendPlus 1.0, which is a Terminate and Stay Resident version of GirlFriend. He discovered that GirlFriendPlus 1.0 expires within a year if you don't upgrade to Fiancee 1.0.So he did, but soon after that, he had to upgrade to Wife 1.0, which he describes as a huge resource hog. It has taken up all his space, so he can't load anything else. One of the primary reasons he decided to go with Wife 1.0 was because it came bundled with FreeSexPlus.Well, it turns out the resource allocation module of Wife 1.0 sometimes prohibits access to FreeSexPlus, particularly the new Plug-Ins he wanted to try. On top of that, Wife 1.0 must be running on a well warmed-up system before he can do anything. Although he did not ask for it, Wife 1.0 came with MotherInLaw, which has an automatic pop-up feature he can't turn off.
I told him to try installing Mistress 1.0, but he said he heard if you try to run it without first uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself. Then Mistress 1.0 won't install anyway because of insufficient resources.
BEWARE!!!! all girlfreind mistress wife and bar fly softwear can cause kid 1.0!!!! this also drains all cashe files and removes future girlfreind programs from being installed properly. also has volume controll issues!!!
:heyyou: 2 can play at this game hunni!! :lol:
The Email:
Dear IT Support,
Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed a slowdown in the overall performance, particularly in the flower and jewellery applications that had operated flawlessly under Boyfriend 5.0.
In addition, Husband 1.0 uninstalled many other valuable programs, such as Romance 9.5 and Personal Attention 6.5, but installed undesirable programs such as Formula One 5.0,NBA 3.0, Premier League, Counter-Strike and World Cup 2.0.
And now Conversation 8.0 no longer runs and Housecleaning 2.6 simply crashes the system. I’ve tried running Nagging 5.3to fix these problems, but to no avail. What can I do?
Signed,
Desperate
The Reply:
Dear Desperate,
First keep in mind: Boyfriend 5.0 is an entertainment package, while Husband 1.0 is an operating system. Try entering the command C:\ I THOUGHT YOU LOVED ME and download Tears 6.2 to install Guilt 3.0.
If all works as designed, Husband 1.0 should then automatically run the applications Jewellery 2.0 and Flowers 3.5. But remember, over use can cause Husband 1.0 to default to Grumpy Silence 2.5, Happy Hour 7.0 or Late Night Teh Tarik 6.1. Late Night 6.1 is a very bad program that will create Snoring Loudly.wav files.
Whatever you do, DO NOT install Mother-in-Law 1.0 or reinstall another Boyfriend program. These are not supported applications and will crash Husband 1.0.
In summary, Husband1.0 is a great program, but it does have a limited memory and cannot learn new applications quickly. You might consider additional software to improve memory and performance. I personally recommend Hot Food 3.0and Lingerie 6.9.
Good Luck,
IT Support
:repost: on the first one, but I hadn't seen the second one. :thumbsup: Mrs. I see you found your avatar :lol:
lol wow yea she got me there! kuto's
wait wait wait...... i got to know what version is alien? lol
Rent this space
I found that ugly old fat hooker vers 1 , stops pop ups.
And self relief version 2 has no nag screens at all.
Not a good idea...
That would work for me.:thumbsup:
to mix in a threesome with the wife...trust me on that!!
Save that for the girlfriend.....
Whatever you do, don't mix in a threesome with your girlfriend and wife and think your cool......not good......I wouldn't know just hear a story from someone.....:headshake
Beginner w/29k miles :o)
:thumbsup::thumbsup::crackup:
are you laughing at my post about 3 somes and what not to do?:dontknow:
laughing at the original post in the thread
1 - 14 of 14 Posts
