Have to use the oem screen as it's designed for this bike at all speeds.
edit: I live in a very windy area; I add this as not sure what you're used to.
I will try a standard screen cheers. Only got a double bubble as im 6foot 4tall.Have to use the oem screen as it's designed for this bike at all speeds.
Well funny you should say that coz that was what i was trying to do.The problem is you're buffering the air. Stop storing it behind the windscreen like that. If you keep buffering excess air there, it will cause your helmet to buffet around. It should be a steady stream of air flow to keep it smooth and there's no reason to buffer it back there. That's your problem. Buffering really only works good to prevent lagging data streams that could cause stepping in the video stream.
:mrgreen:
Buffeting air pockets (as in a non-laminar airflow across the surface) are caused by a difference in flow directions and pressure within the areas of flow. Because you have a higher windscreen, that's making it worse because you create a bigger area of no flow in there. That's a big reason there are cutouts in the fairing near the windscreen to keep the pressure more equal behind the windscreen like it is in front of it. Creating an even bigger disruption with an even taller screen will just make matters more uneven.
So, based on the fact that your helmet is buffeting around (see what I did there?) you need to lower the size of the screen some to allow for more air over the helmet and reduce the size the air gap back there. This can also be improved by sitting closer to the screen you have where the helmet-to-windscreen spacing is less. This will help reduce the amount of air that can get in there and smooth out the flow. Same goes for going lower on the tank when tucking in. Pull yourself forward so you're almost touching the screen with your helmet and get lower in the space. Or just get a smaller screen.
Was actually going to suggest this. Granted it was a different bike but had one of these on my 06 6r. I'm 6'4 and fully tucked I barely felt any wind at 100+.Zero Gravity Corsa
Sent from my XT1045 using Tapatalk
I too have a Puig double bubble and it works fine. On and off track at speeds I don't care to speak of and it's fine.My Puig double bubble works fine up to 175 MPH
