Nope.
Thanks Sky.Nope.
Now I'm confused, lol. Thanks for the reply Crescent.I swear they did. I had a gen3 front wheel on my gen4. They have the same bolt pattern. Should be the same rotors from 2006-2015. 310mm
I checked the part lists, and the code of the front rotors from gen 3 to gen 4 is the same 41080-0159-5C, so I believe they will fit.
Thanks for checking.I checked the part lists, and the code of the front rotors from gen 3 to gen 4 is the same 41080-0159-5C, so I believe they will fit.
I appreciate you double checking Sky!!:grin2:Yeah, part numbers are the same. Not sure what I was thinking. Sorry for the bad info.
Thanks man. That's some good info right there.Gen1 rotors are 300mm
Gen 2-4 are 310mm
Gen5 are 320mm.
I don't know about gen5 but gen1-4 have the same bolt pattern. Skydork just made me second guess myself.
Gen5 are 330mm. :wink:Gen1 rotors are 300mm
Gen 2-4 are 310mm
Gen5 are 320mm.
