If it's the front only you need to swap the headlights/fairing stay then its direct bolt on for the front. The tail requires swapping the subframe. Be advised you will need to figure out the electrical connection for the head lights. I believe they are different. You could just get the connectors for the gen 5 and splice your wiring to it.
