Has anyone tried to fit 06 r1 calipers on to there 06 zx-10r?
good answer:+2:
Ted is correct, the 06 did still have the 4 psiton, they are not a direct fit, like he said though. And they are actually not much better either, best bet if doing swaping, is find some Nissins, or the CBR Tocikos.If I recall correctly, 2006 was the last year of the four piston front calipers. The bolt spacing should be correct, but you will either need to grind off some of the mounting legs (shorten them a few mm's, I think 5, could be 10), or larger rotors.
So, yes, they will bolt on. No, they won't work correctly if just bolted on.
Yeah, the real choice piece from the R1 is the master cylinder, but then you have brake light sensor issues, and it may not be that much better than what you have, depending on your year bike.Ted is correct, the 06 did still have the 4 psiton, they are not a direct fit, like he said though. And they are actually not much better either, best bet if doing swaping, is find some Nissins, or the CBR Tocikos.
Hmmm I've got R1 calipers, galfer oversized ZX14 rotors, and a brembo master. Brakes are rock solid!
Only if you have the calipers modified... You would need to get 5mm or so machined off the bottom of the mounting boss. ZX14 rotors are a direct bolt on and are 10mm larger as I said above.Do you think the r1 calipers will fit with the zx-10r rotors.
Nope, the R1 stock discs are 320mm, the zx10's are 300mm. You will need to grind off 10mm, or get bigger discs.Do you think the r1 calipers will fit with the zx-10r rotors.
Oops!!:lol: Disregard my post...Nope, the R1 stock discs are 320mm, the zx10's are 300mm. You will need to grind off 10mm, or get bigger discs.
