1 - 20 of 30 Posts
trying to get more info before i kick my 10 off in a grave!! i had an epoxy port,cams,decked.012,thin gasket,sidewinder with no baffle and it seemed to not get any faster.whats the secret with these damn heads?
If you are all out drag than it is probably the epoxy port job. My opinion is that epoxy jobs are for road racing and street bikes not drag bikes. Is it a gen 1 or gen 2? Gen 2 head needs bigger valves.
Garth? Where are ya man?? *subscribed* I'm interested to hear what Garth and others have to say on this.
Postwhore with an 04
Also interested :popcorn2:
ive spoke to garth before about an epoxy port before i even got one.he knew how to do one but couldnt really answer most of the ? i had about it.i want a dragracers opinion! :idea:
not so much hurt but takes away some midrange wich you really dont need.it actually picked up a mph when i pulled the baffle.yes a sidewinder is made for peak power and to move air,i actually seen a gain from it.the only reason i got it was for ground clearance...i think i have an answer to my prob anyways.thanks
Speed Freak
all depends on how the bike was tuned really, doing the work to the bike is only half the job. maybe you should find a good tuner and know what parts make what power.
what year is the bike. As i stated before epoxy jobs (my opinion) are for road racing bikes. You dont gain a bunch of top end power from them. YOu can show me a dyno before and after doing an epoxy job and there is a huge gain down low and overall but you have to take in consideration must of the time you are setting the squish tighter at the same time. I think you should get another head done(not epoxy) and if turns out better for you then sell the epoxy job to a road racer.
I have a ported head. It really needs to be matched with the cams and motor to have the full package otherwise your just kinda slinging crap and hopefully something will stick. Dwayne at Cycle Concepts did my package and knows his stuff:thumbsup:
Discussion Starter #12
i spoke with Dwayne today and i believe he has pointed me in the right direction and put some things on the table i havent thought of.cam timing could def be an issue...esp seeing that Kawasaki recommends setting the 08 race cam to 110-111 i believe...dont hold me to that but i know its something like that.if thats the case i have it set for pure midrange wich offers my setup NOTHING.another thing is that in my head kawi didnt design the "race" cam for dragracing.this cam seems to be real strong in the midrange area put planes off in the top end.im also seeing my 330 numbers in the 5.7x range but after that its losing something somewhere.i know my 10 by the back of my hand and with every pass from the 60ft to the traps i can tell you what the bikes doing,so i def know where im at a power loss.taking the head off and doing another port is just throwing parts at it.Ryan Kallina did a outstanding job on my head...ive just got to figure out what cam package/ or magic # im looking for.thanks for everybodys opinion on this
Ha, no kidding, I talked to Dewayne today about the 08 race cam too.
tens love sidewinders,especially with compression. that 08 cam is short on duration, hence the high lobe center for some top end. thought about trying it myself. decided on basic web regrinds, not hardwelds because of budget. also, unshrouding intake valves is almost comparable to adding lift, and the ten is shrouded. keep sharing, good info. helps me with my motor, and dont get discouraged, making a bike fly is a process.
Discussion Starter #15
ok had a chance to go out last night,despite having some sir shifter issues i played with the tune a bit and didnt see results.on the last 2 passes i added 2 deg of timing and came to life!i believe its safe to add another 2 deg giving it +4 total.im gona try this setup fri night before i move the cams to 109/109....also anybody dragging the 08 10?i set one up for a guy and it seems to have the chatter issue like the zooks before a clutch mod,it has a diff steel setup in it thats causing this i think.im gona put a 04 setup in it tonight and see if it resolves the issue
Discussion Starter #17
I drag my 08 all the time. Only had chatter problems when I was SWB and extremely slow on the clutch...
this means your throwing the clutch away,u have to slip the clutch if u wana see good 60fts and 330's.your right i was testing it trying diff things and if you throw it away u wont feel it but i launch hard and if i dont see a 1.36-1.38 every pass i might as well load it up because anything less just dont cut it :thumbsup:
I'd say throw more timing at it as long as you're fuel will hold it. As for the clutch, I'm really happy with my 06 and I'd assume the 08 is pretty similar. Mine lasted all last season racing swb, w/ 1.58's and is still in the bike now. I have to relearn how to ride a long bike and have only cut a 1.51 with it as it sits now @ 62". It seems like the only time it chatters is during a dry hop.
Discussion Starter #19
update:eek:k so this was def a cam timing issue.i went to my tuner and got a dyno graph comparison of my stock motor vs ported head setup and its makin all the power in the midrange from idle to 8500 rpm...this does me no good at the track.although if i wanted a street bike it would make for nasty power.i moved the cams to 109/110 last night,when i got it back running i could already tell a diff in the way it reved on the bottom end,was def slower...this should make for alot more peak power.weather permitting im gona test wed night and hope for the best.i also removed the secondary butterfly shaft from the throttle bodies,what diff this will make i dont know but it should at least help things flow better.the only thing i dont like about it is that you have to help the bike warmup.
Discussion Starter #20
:idea:this def worked.e.t.,mph,330...everything picked up gain.i can feel the true power of this setup now.im not sure if 109/110 is the right # for this setup but it def works for me.the bike ran 5.7x's in 80% humidity with my 190lb ass on it,and it would only do this before in cold air and u4.2. now it does it on pump gas:mrgreen:
1 - 20 of 30 Posts
