1 - 9 of 9 Posts
I've searched, searched, and searched. I'm finding a lot of similar stories but no direct answer.
I'm hearing a whistling noise not a squeak when my clutch is pulled in. Happens once bike is warmed up, and happens both in gear and in neutral.
Has anyone had this issue? Or have any idea's what It could be?
Thanks Much,
Danny
It was indeed rubbing against the clutch cover, however they also changed the pull rod, a bearing, and the release-comp-clutch as the bill states lol I'm not sure what bearing, or what the release-comp-clutch is, but its fixed and I'm thrilled. I'm pretty cool with the service guys over there I'll try and get a more appropriate answer for you.
im at 23k miles, and the cost was $136 in parts and $133 in labor, so $270 ish
Parts included
Rod $49.95
Bearing-Ball $21.95
Release-Comp-Clutch $42.95
Gasket, Clutch Cover $ 21.95
Hope that helps
Parts included
Rod $49.95
Bearing-Ball $21.95
Hope that helps
Thanks, my bike is making some noise and am looking at possibilities. I'm at 33K.
thanks.... i had just changed my clutch and now i have this crazy noise i have been losing my mind :BangHead: so now i guess ill be getting back into that clutch case ..... not looking foward to that... but thanks for the info:eek:ccasion1
1 - 9 of 9 Posts
