1 - 7 of 7 Posts
It just started Thursday night. Off idle @ about 2000 rpm I hear this whistle type noise. Almost sounds like a bird cooing. Best I can discribe it.
Sounds like its coming from the left side around the front sprocket area....
I even hear it when riding or sitting in the garage just bliping the throttle. I thought water pump. Thought Mybe I had run low on coolant or something. Never had a leak, but I checked anyways. No leaks, coolant level is great. I'm due for an oil change.
Could it be that Its time for an air filter? I plan on putting a new one in this week.
If anyone in Dallas knows much about these and will take a look @ it, I'd be thankfull.
its not your gas tank making that noise is it?? mine does it after i ride it and park it but not when riding it ??? other than that i have no clues really?? hard to tell what it is ? good luck with it..
Discussion Starter · #3 ·
ive never heard my tank vent...wifes ZZR does. This is different.
Does it cold or hot.
Check your air filter housing for proper fitting.
Yeap, the valve in the gas cap let the gas fumes escape from the tank anda that makes a whistle. Usually it whistles more when your tank is almost empty (more space for gas fumes in the tank) :wink:
Discussion Starter · #5 ·
guess now that I'm home I'll lift the tank....
hey m8
sounds EXACTLY like mine, your stator in generator / alternator is burning out and bits of it are rubbing as it spins...
mine made bird sounds for a few hundred miles before generator stopped outputting alltogether and battery went flat, then I broke down :(
think it will need replacing... best check it before it goes altogether.
Discussion Starter · #7 ·
well I emailed Kawi about this. They said to take it to a dealer, have them call the tech line and we'll go from there.
Is there a trusted Kawi dealer in the Dallas area?
1 - 7 of 7 Posts
