1 - 7 of 7 Posts
Thinking about doing a thing head gasket on my 08. Stock motor, pump gas bike. I may add a race intake cam before installing it.
Which do I need? .45, .5, .55, .60mm????
I've been wondering if the .45 head gasket offers enough piston valve clearance on the '08 as they run a higher compression ratio than the previous ZX-10R's.
The kit intake cam has the same lift as stock ('08) but 4 degrees more duration. I doubt we'll see big increases with this cam compared to the previous generation's kit cam.
Hmmm, I definitely don't want piston/valve clearance problems. However if Garth runs 13:1 on his 2mil pistons with the .45 gasket I should be fine I would reckon.
Garth had 13.5 pistons, a .45 gasket and a shaved head at a total of 14.5:1.
I think you will be fine, no issues.
1 - 7 of 7 Posts
