1 - 8 of 8 Posts
Banned
i am installing a dry nitrous kit. it says to put the fogger before the mass air flow sensor. isnt the sensor in the back of the airbox? someone told me to put it in the side of one of the rubber boots that go into the airbox right before the air filter. where are you guys putting yours?
Some people put it in the ram air duct. I'll try to find you a pic.
Well I think the pictures are on my home pc so I will try later.
Mine is in the airbox. If you put it before the airfilter it won't hit as hard as if you put it in the airbox. If you wanted it to hit hard with it before the filter, just take out the filter. Remember though, that the boot you would want to put it in is inside the frame. If you put it anywhere farther forward you will lose nitrous into your frame and not get the full effect.
rated zx is right.
I shimed my gas tank up and place to fogger nozzles on the air box lid
I place them as close to the filter as possible I will tak some pics and show you in a day or two
1 - 8 of 8 Posts
