1 - 20 of 21 Posts
so im getting more and more into drag racing, but still want it streetable....so far ive been told by everyone and their mother to do the clutch mod but cant get a straight answer on what it is. so that leads me here, can someone please explain this CLUTCH mod i need to do. thankyou in advance and all links to purchase parts is a great help as well
You have the BEST clutch in the gen 1, the clutch mod is for other gens to put a 1st gen clutch in there bike. No clutch mod needed on the first gen besides maybe heavier springs
MIdlife PIMP
I was told by a well known drag racer of Kawasakis to replace every other spring with a GSXR1000 spring!.not all the springs........but every other spring!.and always buy factory plates and fibers....not to go aftermarket!.........hope this helps!
so heavier springs is something i need?? id imagine that just helps with the clamping pressure? where might i aquire some of these heavier springs
yep and check out brocks performance for the springs. im runnin a set with stock clutch plates and its working nicely.
i just checked their site and they dont make them for our year bike so what springs might you be running??
oh ok, they screw right in?? what is the basic need for better springs?? like that am i going to gain from this if ya dont mind taking a second and explaining it to me
yes they go right in. you will get a better clutch grab/lever feel and i seen a slight mph increase with em.
Discussion Starter #11
very nice, so just the springs is all i need, i dont need the cushions?? ordering springs now i think, gotta check with the banker lol
That use to be the case, until dwayne at concept cycles started selling his drag pak, it is a better clutch that OEM, drag racer or not.
yep thats all you need. brock dont offer a clutch cushion kit for the 1st gens.
:+2:
Slow Poke
I had a stiffer spring every other one and shims on all of them and it was great! but cycle concepts makes one HELL OF A CLUTCH!!! I won't buy anywhere else after having one
NOTHING, just call dwayne and tell him you want a first gen clutch with judder steel
1 - 20 of 21 Posts
