4 days ago I went to start up my bike and when I turn the key to the on position the gauges lit up however no noise came from the fuel pump or servo. When I tried to start the bike it tried to turn over but didn't. Also while holding the start button down the FI light flashed rapidly however when I stopped pushing the start button the FI light turned off. I disconnected the battery and let it sit for about 30 min. After reconnecting the battery the bike started up fine. I turned the bike off and on several times and roughly 3 out of 4 times it would do the same thing as before (no fuel pump priming noise or servo noise) but 1 out of 4 times it would start fine. Then yesterday it gave me the silent treatment with the flashing FI light (only when pressing the start button) however this time disconnecting the battery changed nothing. Now, this morning I reconnected the battery (after leaving it disconnected all night) and when I turned the key on not only did the fuel pump and servo stay silent but there was a rapid ticking noise coming from the relays directly posterior to the battery. The almighty -OP- came over and tried to help diagnose the problem to no avail.
Here's a list of what we tried:
-Put his battery in my bike
-Connected his servo eliminator to my bike
-Disconnected my power commander
-Checked fuses, connections etc.
Bike was running perfectly up until it suddenly went silent. ANY suggestions or help would be greatly appreciated. Thanks y'all
