1 - 8 of 8 Posts
Hi all,
When my engine isnt running , my F1 indicator does flashing all the time....is that Oke'?
When its running.....F1 is burning all the time......dont know if its burning all the time when the engine is on temprature....because i have the Kawa for just a month...and its only for circuit .....its agains the law to drive this on the road.(no title)
Thanks for reply and support.:eek:ccasion1
Eddy
you will need to pull the codes to see why the FI light is on... its lil plug underneath the driver seat you can jump to see wat code is popin up.
Does not drive into smoke
There is a wire there that has a vinyl tube at the end. You need to stick another wire in there and route it to the ground (like the frame). Then turn the ignition key and the FI light should emit a series of flashes: long and short. Count the long ones, then count the short ones, together you'll get a 2-digit number. That's the code.
Servo's Eliminatus ;)
Did you ever figure it out ???
Update us
1 - 8 of 8 Posts
