I have lost clips with this type of connecting link. More than once. You can safety-wire it, RTV it, doesn't matter, they can and will come off. Then you only have the friction of the pressed link plate holding it in place. Just saying.Pro-Stock / Top Fuel drag bikes use "non o-ring/x-ring" chains and
use just roller chains, they also use clip type master links.
Clip type master links make it much easier to make sprocket and swing arm changes and also to clean the chain.
Nothing wrong with clip type master links.
I never use clip-type on bicycles, either. Use the tool and press on the new connecting link (it's actually a connecting pin with Shimano, SRAM makes a good hybrid clip with a double-reverse connection). You be climbing up a steep hill putting a load of torque on that chain, if it busts you can fall, it hurts, not to mention the chain getting jammed in the derailer.Rivet, always rivet. Clip style are only safe and suitable for bicycles and a lot of knowledgeable and powerhouse cyclists even question the use of them for bicycles too.
