1 - 10 of 10 Posts
2014 ZX10R
Discussion Starter · #5 ·
Part number is in the description of that eBay link if you want to look for it elsewhere. You will also need a couple of the pop-pins that hold it in place if those are missing
Stupid question but is the part you posted just for the left side? It's missing that piece on both sides, I posted another picture of it.
Each side has one rivet at the front, an Allen bolt in the back, and a bolt through to the side fairing underneath. The ones underneath also normally go through the charcoal evap filter on the right and the rectifier on the left. The Allen bolts need rubber well nuts to go into if those are missing.
rivets: 92039–0068
Well nuts: 92015-1757
Allen bolts: 92154-0209
if you search through the oem parts diagrams on revzilla I think they offer an assembly order with all the right pieces and you’ll get it cheaper. Search your year model and look under body/lower fairing/cowl
2014 ZX10R
Discussion Starter · #9 ·
rivets: 92039–0068
Thanks so much. One more question: do you know the part number for the cowl on the bottom of the front fairings? I took a picture of a ZX10R I saw with the part.
447951
As mentioned, you can look all that information up yourself from the parts fiche.
Like here:
447952
Part 55028D is: 55028-0335
1 - 10 of 10 Posts
