Ok so my 05 ZX6R is having major cooling issues which I'm in the middle of resolving. Break down of problems. Overheat; it's died on the highway a couple times and flashed 118 C/245F and the radiator fan doesn't come on at all. Bike also overheats on while moving.
I just finished draining the coolant and is was red/brown. I let the bike reach 90C before draining. First draining location I tried was the 8mm bolt on the water pump and almost nothing came out. I then just started, one at a time, hoses from lowest positions.
I'm changing the temperature sensor and thermostat. I'm also going to do a visual inspection of the water pump. Also going to check fuses and make sure the fan works.
Going back to the original question is there anything else that can rust? I'm pretty sure I don't have a coolant leak anywhere and the exhaust is normal, no white smoke and the last time I rode the bike was at the strip and the motor was super strong like always.
