1 - 6 of 6 Posts
So, I've looked through thousands of posts hoping to find some help on my problem....I have a Vortex rear brake Pressure switch with my vortex rear sets. About a week ago, while riding I figured out that my brake light is coming on and staying on! I have it narrowed to the rear switch, I was just wondering if anyone has ever had this kind of problem with these, and if so, how do I fix it??
Supercharged Mod
Replace the switch with a new one. They're not all that expensive to buy separately ($20-ish IIRC) so it's not worth trying to repair.
I was just hoping someone might have a quick fix...no one around here actually stocks them, and I have to have it working to ride on base. O-well, guess I'll just order a new one!
Certified SLOW
Man do they do a walk around of your bike before you get on base or something? That's nuts. Either way, it's not very safe to be riding with your brake lights constantly on. Stay safe, and good luck.
also check the pedal adjustment on your brake pedal. may just be not set correctly for enough slack for pressere switch.
take it off.
take the preasure switch off until you can get a new one and put a regular brake nut back in the master. You never use the rear brake without the front brake anyways, quick fix until it comes in. Then you can ride. takes 5 minutes.
1 - 6 of 6 Posts
