its not over full untill its foaming just fyi, i allways ran oil to the top of the sight glass on my zx10got to looking around on the bike to see if i could find the problem sure the valve cover is sweating a little bit but im pretty sure i found the cause of the oil leak i was seeing. i recently just bought the bike from a dealer i put about i would say 200 miles maybe on it parked it and saw it leaking so i took all the body work off and was looking around under the header all over. came to looking at the oil filter yup there it was the dealer forgo to tighten the oil filter and they even over filled the oil by about 3/4 of a liter pretty sure im only buying from private sellers from now on
what he said, a very thin coat is all you need...:thumbsup:I used a thin layer of black rtv silicone all around when i put a new gasket on. Figured it won't hurt. Haven't noticed any leaks after.
Not normally but if there leaking it will be visible when you pull the coil sticks out.Mine is sweating and I’m going to replace the valve cover gasket.
Do I need to order the four plug hole rubber gaskets too?
