1 - 6 of 6 Posts
Custom Powder Coater
Can't seem to get this leak too stop... (new motor) At first oil was leaking through gasket/head... So replaced gasket and now it's seaping between cover and gasket(oil is coming over gasket).. I'm guessing the cover is warped/bent (brake side front corner) as the gasket is new and bolts are torqued correctly... Any opinions on what I can do too fix this....
my 05 cover had to be replaced. the cover would rock back and forth on a flat surface. I could slide about 4 or more playing cards under it.
Fixed!!! Removed cover inspected and found hairline crack were its leaking, slapped on spare and all good.. now to get her tuned :)
Need a spare valve cover? Probably cracked in shipping.
Thats what i figured as well, shipping damage...
U got one? How much? I need one for my original motor now that i used it..
1 - 6 of 6 Posts
