Hey Folks,
I'm in the process of doing a valve check and I'm curious if the valve cover gasket is reuseable and if it is reuseable how many times can you reuse the same gasket? I bought this bike second hand and I'm not sure if the gasket was ever reused so I'm abit curious if I might be able to get away with using the same one. If I do reuse the same gasket, do I use a gasket sealer along the whole surface. In the service manual it looks like the gasket sealer is only where the camshafts lay.
Thanks
Thanks
