1 - 6 of 6 Posts
Anybody know the valve clearance adjustment for intake and exhaust.
For 2004 zx-10r, and it's not the same number for 2006 where the valve clearance number change...
So thanks.
Standard:
Exhaust- 0.17-0.22mm or 0.0067- 0.0087in
Intake - 0.15-0.24mm or 0.0059-0.0094in
Race:
Intake- 0.22mm
Exhaust- 0.20
Squish - 0.85
Valve
Anybody try to adjust they're valve ???
Now on this model did I have to remove the radiator ???
Did I need to detach the motor from the frame.
They're a lack of space, even the rubber mat seem a little bit hard to pull out. Did we got a book somewhere on line for this mechanic of zx-10r (2004) ???
So ihave the 2004 zx10r and I bought the stock retainers for an 08 zx10r appreciate apon research they fit will that change my valve clearances if the are a bit thicker
no, valve clereance determined by the length of the valve stem which is what the shim must ride on, retainer has no effect there.installed valve spring height should remain constant.
1 - 6 of 6 Posts
