1 - 6 of 6 Posts
zx10-rr
¿Are there any reading material on using KIBS on curves?
The manual says that should not count on the system saving you. But Im guessing is just a way of covering their backs.
I wold like to know how to use this system. Also the cornering management system.
ABS is just anti skid....it's not going to work on the curves for normal riding.
For track day riding you remove the two fuses under the seat to disable it...as it will cycle during hard braking.
zx10-rr
Discussion Starter · #3 ·
Im talking about the 2018 model where ABS works in curves.
These models come with a Bosch IMU which calculates 5 axes it then uses to control the ABS, engine braking, and other shit I don't know about and would like to learn more.
It does help with keeping the bike from standing up in corners when panic braking. It does so by letting off the front brake a little and feeding in rear brake (or at least that's what I read in a magazine). I can say it works.
Mike
zx10-rr
Discussion Starter · #5 ·
Mike
Too bad that non of this info comes in the manual.
1 - 6 of 6 Posts
