1 - 20 of 26 Posts
I've been reading some posts about suspension and i am looking to upgrade.I asked my suspension guy if i should put gold valves in and he suggested cartridge kit instead with rebound and compression and said that was the cure for big piston forks.I ride a 2011 10r and i don't do track days but but like to ride aggressive on the street.I have upgraded to an elka rear shock and would like to get the most out of the front as well. Please any good suggestions would be appreciated.Race tech offers a gold valve kit for the bike and that would be the way i would like to go if its not wasting my money of course.
How did you like the rear shock after you swapped it out?
I've yet to try it yet,seeing as there is still 3 feet of white shit still in my yard. i'm getting it ready for spring and would like to find out more for the front end so as to have it all ready. I have also ordered spiegler brake kit and looking forward to installing it just to keep me busy and pass the time till spring.
I've just put a ketch ssk piston kit in my 08 forks one word awsome my bike is mainly used for fast road riding I wouldn't imagine u would need anything more for road use.
Unless you're seriously fast, the BPF's are quite good and don't need anything apart from the correct springs for your weight.
Thanks guys for the feedback, ktech may be the way I go then but if anyone has experienced the good valve I would like to hear about .
just out of curiosity, why do you plan to choose ktech over ohlins? been thinking of upgrading my forks as well, and was just curious to hear your thoughts.
I assume your talking about the Ktech 25mm open bath carts? and comparing them to Ohlins NIX 30mm open bath carts?
Op. don't bother wasting your money on the racetech kits.
I assume your taking about the Ktech 25mm open bath carts? and comparing them to Ohlins NIX 30mm open bath carts?
While we r waiting for his response - Bigunz can you give any insight into how those compare? Is comparing the 25mm to 30mm possible or t they different animals? Suspension is my area of least knowledge and I'm always trying to learn and understand more...
Sent from Motorcycle.com App
Discussion Starter #12
Bigguns, I'm just wondering if you have experience or read some where about the race tech? It's not that I'm a big fan , it's because I really don't know the difference and I see so many different opinions it's hard to choose. But ktech seems to be the general idea.
There two completely different designs, how they build pressure needs to be taken into account in more ways than some think. On top of that the design on the rear needs to work with it..
Remember when the TTX first came out (well.. came back around anyway) there was people saying it was shit and others saying the opposite. Most of the time the people who didn’t like it didn’t understand the tech and/or know how to adjust it. (still happen today)
Each design give's a different feel, some like one more than the other.
In a way for less money, you can get a similar result with a reshim of the stock valves ( Depending on the tuner ) which is not really worth it either, but it would make them a little better as the problems that are inherent to the BPFs will still be there. Best place for the insides of the BPF’s .. is in the bin.
What about GP suspension carts?
if you have a Gen 3 or the DLC coated forks you may not want to disassemble the fork bottoms to install the gold valving kits. I haven't done it, just what I heard. Unless you get new fork tubes then it's fine.
Discussion Starter #16
Thanks bigunz, and that's what my tuner also said about bpf is you need to replace the entire inners and start over. So I guess I wait till I can afford the cartridges and go that route! Just wanted to say thanks to all that replied and offered there support.
I chose the ketch piston kit because they had 2 options one for street 1 for track that's the reason why I chose the Ktech and if u are not doing track days I wouldn't bother with the cart kits as u need to really be riding very hard to get them 2 work properly this I what my Ktech man told me .I would go the Ktech piston kit if u ride on bumpy roads they work and u won't want anything more especially if u are just road riding I push on a bit on the road and I can't out ride this setup . If u have $ to burn get the dds Ktech Cart kit :) than u won't have to upgrade again .
Do Ktech make piston kits for BPF... :icon_confused: And their pressurised carts would really be overkill for his intended use.
I disagree....I have the Ohlins 30 cartridges and use them on the street and on the track and they're perfect in both applications....they need some miles to heat them up, but that's about it...
huh?? Those are not pressurised.. and I have the same on my other ride:wink:
1 - 20 of 26 Posts
