1 - 14 of 14 Posts
Well I finally got to ride yesterday – 70 mile commute and I must say I am extremely impressed though a little deaf in my right ear. The sound has changed both in frequency and volume. I wear custom earplugs if I want to listen to music which I will no longer be able to do as I still have a ringing in my ear so I am going to have to go back to using only foam earplugs (they have a rating of -33 dB) but the sound is amazing. I think the ringing has come more from the exit point position and my riding position as it exits right below my ear instead of slightly behind me but nonetheless I am sooooooooooo happy.
Once the pipe color changes a little I will post up some good hi rez pics but here is the only one I have.
Discussion Starter · #11 · (Edited)
sorry i know people are busy...but ill put in a request...think you can add a video or some kind of drive by....i wanna order this...but i wanna hear it first!
I will try but it has been hard since I have ridden little since my wife's accident. If you search on Youtube I have a clip with it at idle and revving (it is a poor clip) but you get the idea. The new 200mm is much louder and meaner sounding than the 260 but you NEED earplug as the exhaust exit causes the sound to resonate in your helmet. THere wasn't a window open in the Intersate yesterady :)
Discussion Starter · #13 ·
sweet thanks....power wise is the 200mm vs 260mm better or worse
So hard to tell as the weather was quite a bit cooler yesterday so it felt like it had more power but that was due to cooler air going in. Powerwise it is probably the same just much louder.
My ears are bleeding just looking at that....but it does look good. If I had it I would have the DB killer installed I am thinking...
1 - 14 of 14 Posts
