Ok so here it goes I have acquired both a brembo bracket and a pvm bracket along with associated calipers. An today I recently stumbled upon the information that the gen 2 brake bracket is not the same as the one for gen 1/3 and as far as I can tell the only difference is the brake block position that the hanger slides onto the gen 2 is linear to the axle hole while the gen1/3 are slightly above it. Is this the only difference between the two because my plan was to cut that block off and re-weld it in the appropriate position to fit the bracket. Just thought I ask to see if any one has some input or information.
